Ga door naar hoofdinhoud
Insignia NS-B2110 Speaker Replacement
Wat je nodig hebt
  1. Insignia NS-B2110 Speaker Replacement, Battery: stap 1, afbeelding 1 van 2 Insignia NS-B2110 Speaker Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Speaker Replacement: stap 2, afbeelding 1 van 2 Insignia NS-B2110 Speaker Replacement: stap 2, afbeelding 2 van 2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
  3. Insignia NS-B2110 Speaker Replacement, Bottom Panel: stap 3, afbeelding 1 van 1
    • With a Phillips #2 screwdriver, remove two 2mm screws.
  4. Insignia NS-B2110 Speaker Replacement: stap 4, afbeelding 1 van 2 Insignia NS-B2110 Speaker Replacement: stap 4, afbeelding 2 van 2
    • Using a long Phillips #2 screwdriver, remove one 6mm screw located inside the battery compartment.
    • Use the same screwdriver to remove four more 6mm screws along the outside of the case.
  5. Insignia NS-B2110 Speaker Replacement: stap 5, afbeelding 1 van 3 Insignia NS-B2110 Speaker Replacement: stap 5, afbeelding 2 van 3 Insignia NS-B2110 Speaker Replacement: stap 5, afbeelding 3 van 3
    • With a plastic opening tool, wedge the bottom shell from the main speaker face along the edge.
    • The bottom cover has two red and two yellow wires attached to it that you don't want to pull off. Handle the casing carefully.
    • Once the pieces are separated, pull them apart and place the bottom cover aside, near the stereo.
  6. Insignia NS-B2110 Speaker Replacement, Internal Components: stap 6, afbeelding 1 van 2 Insignia NS-B2110 Speaker Replacement, Internal Components: stap 6, afbeelding 2 van 2
    • With a Phillips #2 screwdriver, remove five 5mm screws from the "quarter circle" circuit board.
    • More wires! Handle the circuit board carefully and take caution not to stretch the red and white wires connected the board to the other components.
    • Remove the green quarter circle circuit board and place to the side.
  7. Insignia NS-B2110 Speaker Replacement: stap 7, afbeelding 1 van 1
    • On the brown side of the quarter circle circuit board, remove the two white ribbon cables with pink stripes attached to a plastic connector. To do this, pinch the tabs with your hands while pulling outward on the connector.
  8. Insignia NS-B2110 Speaker Replacement: stap 8, afbeelding 1 van 1
    • With a Phillips #2 screwdriver, remove four 6mm screws from the rectangular circuit board.
  9. Insignia NS-B2110 Speaker Replacement: stap 9, afbeelding 1 van 1
    • Remove the two white ribbon cables attached to white plastic connectors from the circuit board by pinching the tabs with your hands and pulling outward on the connector.
  10. Insignia NS-B2110 Speaker Replacement: stap 10, afbeelding 1 van 1
    • Red and white wires are attached to this board as well. Once again, be careful not to stretch these.
    • Remove the rectangular circuit board and place it to the side.
  11. Insignia NS-B2110 Speaker Replacement: stap 11, afbeelding 1 van 1
    • With a Phillips #2 screwdriver, remove two 5mm screws from the black plastic frame which previously held up the rectangular circuit board.
    • Remove the black plastic frame.
  12. Insignia NS-B2110 Speaker Replacement: stap 12, afbeelding 1 van 2 Insignia NS-B2110 Speaker Replacement: stap 12, afbeelding 2 van 2
    • With a Phillips #1 screwdriver, remove four 3mm screws from the silver metal circuit board.
    • This board has two white ribbons attached to it. Once again, be careful not to stretch these.
    • Remove and place the metal circuit board to the side.
  13. Insignia NS-B2110 Speaker Replacement: stap 13, afbeelding 1 van 1
    • With a Phillips #2 screwdriver, remove the two 3mm screws from the black plastic tuner frame.
  14. Insignia NS-B2110 Speaker Replacement, Speaker: stap 14, afbeelding 1 van 3 Insignia NS-B2110 Speaker Replacement, Speaker: stap 14, afbeelding 2 van 3 Insignia NS-B2110 Speaker Replacement, Speaker: stap 14, afbeelding 3 van 3
    • Using a Phillips #2 Screwdriver, remove two 5mm screws from the speaker.
    • The edges of the speaker are very thin and sharp and could cut your finger.
    • The speaker will have a light coating of glue to hold it in place. A little force from your fingers will pull it right out. Remove the speaker and set it face-down on the table.
  15. Insignia NS-B2110 Speaker Replacement: stap 15, afbeelding 1 van 1
    • Remove the solder from the two black and white wires connected to the speaker.
Conclusie
Jacob Phillips
313 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-31, Amido Fall 2013 Lid van Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 10
Altijd: 1,022
