Ga door naar hoofdinhoud
Insignia NS-B2110 Battery Replacement
Wat je nodig hebt
  1. Insignia NS-B2110 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Insignia NS-B2110 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Flip the stereo so the CD opening is face down.
    • With two fingers, pinch the tabs and lift up to open the battery protection cover.
  2. Insignia NS-B2110 Battery Replacement: stap 2, afbeelding 1 van 2 Insignia NS-B2110 Battery Replacement: stap 2, afbeelding 2 van 2
    • Using a spudger or your fingers, push up against the positive end of the battery. Once it is loose, lift the battery out.
    • Repeat until all eight batteries are removed.
    • Make sure the batteries are facing the right direction. If the device does not turn on, you may have the batteries in the opposite orientation.
Conclusie
Daniel Hodges
301 Reputatie
3 handleidingen geschreven
Cal Poly, Team 4-31, Amido Fall 2013 Lid van Cal Poly, Team 4-31, Amido Fall 2013
CPSU-AMIDO-F13S4G31
4 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 356
