Inleiding
This guide will take you through the process of replacing speakers in an Insignia TV.
Wat je nodig hebt
Rest the TV on its top edge so you have access to the base.
Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
Remove the base from the frame.
Stand the TV on its top edge.
Gently pry apart the front and back of the TV.
Remove all the pieces of tape to detach the wires from both sides.
You want to gently peel the tape off, without pulling on the wires.
Unplug the red (right speaker) cord from the motherboard.
Unplug the white (left speaker) cord from the motherboard.
