Inleiding
Use this guide to replace the infrared sensor in your Insignia NS-24ER310NA17 television.
Wat je nodig hebt
Rest the TV on its top edge so you have access to the base.
Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
Remove the base from the frame.
Stand the TV on its top edge.
Gently pry apart the front and back of the TV.
Remove all the pieces of tape to detach the wires from both sides.
You want to gently peel the tape off, without pulling on the wires.
Remove all strips of tape attached to the silver steel rectangular piece.
Unscrew single screw holding IR sensor and remove sensor with ribbon cable.
Place the new sensor where the old one was and replace the screw.
