Ga door naar hoofdinhoud
Insignia NS-24ER310NA17 Disassembly
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. Insignia NS-24ER310NA17 Disassembly, Remove the base: stap 1, afbeelding 1 van 3 Insignia NS-24ER310NA17 Disassembly, Remove the base: stap 1, afbeelding 2 van 3 Insignia NS-24ER310NA17 Disassembly, Remove the base: stap 1, afbeelding 3 van 3
    • Rest the TV on its top edge so you have access to the base.
    • Use a Phillips #2 screwdriver to take out the four screws on the bottom of the base.
    • Remove the base from the frame.
  2. Insignia NS-24ER310NA17 Disassembly: stap 2, afbeelding 1 van 3 Insignia NS-24ER310NA17 Disassembly: stap 2, afbeelding 2 van 3 Insignia NS-24ER310NA17 Disassembly: stap 2, afbeelding 3 van 3
    • Lay the TV face down.
    • Use the Phillips #00 screwdriver to remove all of the Phillips Head Screws from the the back of the TV.
  3. Insignia NS-24ER310NA17 Disassembly, Pry the TV open: stap 3, afbeelding 1 van 1
    • Stand the TV on its top edge.
    • Gently pry apart the front and back of the TV.
    • The two halves should pull apart easily since there are no longer any screws holding it together.
    • The two halves will still be connected by wires and cables that are taped to each side. Do not pull on these. We will remove them in the next step.
  4. Insignia NS-24ER310NA17 Disassembly, Disconnect wires: stap 4, afbeelding 1 van 3 Insignia NS-24ER310NA17 Disassembly, Disconnect wires: stap 4, afbeelding 2 van 3 Insignia NS-24ER310NA17 Disassembly, Disconnect wires: stap 4, afbeelding 3 van 3
    • As mentioned in the previous step, there are wires still connecting the two halves.
    • Remove all the pieces of tape to detach the wires from both sides.
    • You want to gently peel the tape off, without pulling on the wires.
  5. Insignia NS-24ER310NA17 Disassembly: stap 5, afbeelding 1 van 1
    • Spread apart your TV the rest of the way, but do not disconnect any of the wires.
    • You should have a clear view of the inside on both sides.
Conclusie
Hannah Berenjfoorosh
533 Reputatie
3 handleidingen geschreven
Cal Poly, Team S16-G2, Banghart Winter 2018 Lid van Cal Poly, Team S16-G2, Banghart Winter 2018
CPSU-BANGHART-W18S16G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 42
