Ga door naar hoofdinhoud
Insignia NS-15MS0832B Power Button Replacement
Wat je nodig hebt
  1. Insignia NS-15MS0832B Power Button Replacement, Power Button: stap 1, afbeelding 1 van 1
    • The power button is located on the top side on the tablet, along side the charging port and MicroUSB port
  2. Insignia NS-15MS0832B Power Button Replacement: stap 2, afbeelding 1 van 1
    • Starting in the corner, carefully insert the plastic opening tool.
    • Work the plastic opening tool carefully around the entire device to pry it open.
  3. Insignia NS-15MS0832B Power Button Replacement: stap 3, afbeelding 1 van 1
    • Once the tablet is completely open, set aside the back half.
    • Carefully place the other half of the tablet screen-side down.
  4. Insignia NS-15MS0832B Power Button Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Using tweezers, gently grab the power button and pull it out from the tablet.
  5. Insignia NS-15MS0832B Power Button Replacement: stap 5, afbeelding 1 van 1
    • Once the faulty power button is removed, follow the directions in reverse order to reassemble the device.
Conclusie
Harrison Smith
329 Reputatie
3 handleidingen geschreven
Texas Tech, Team 1-1, Bennett Fall 2016 Lid van Texas Tech, Team 1-1, Bennett Fall 2016
TTU-BENNETT-F16S1G1
4 Leden
6 handleidingen geschreven
2 opmerkingen
If the power button doesn’t physically click anymore, can you order a replacement? Is it even possible to solder on a new power button?
Thanks in advance…
Chris - Antwoord
Can you do this with the volume rocker? My Insignia tablet has a faulty rocker, and I need to fix it. (Note- the “+” part of the volume button sticks and jams the volume to 100 until I press “-”.)
Andy Joonseo Bae - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 1,010
