Ga door naar hoofdinhoud
Insignia Flex Elite 7.85 Camera Replacement
Wat je nodig hebt
  1. Insignia Flex Elite 7.85 Camera  Replacement, Back Camera: stap 1, afbeelding 1 van 1
    • Make sure the device is turned off before taking it apart to avoid any injuries.
    • Use a plastic opening tool to remove the metal backing of the tablet.
    • Insert the plastic opening tool between the screen and metal backing. Use a prying motion to lift the front case from the metal panel.
    • Move the tool around the perimeter of the device until the screen separates.
    • The volume and power button will become free from device when the screen and metal backing are separated. These small pieces are easy to lose, be careful. They’re easy to put back into place when reassembling the tablet.
  2. Insignia Flex Elite 7.85 Camera  Replacement: stap 2, afbeelding 1 van 2 Insignia Flex Elite 7.85 Camera  Replacement: stap 2, afbeelding 2 van 2
    • Once the the tablet is open, locate the camera.
    • There is a small black ribbon connector which connects the camera to the motherboard.
    • Use a plastic opening tool to pry slightly on the black ribbon connector.
    • Bend the black ribbon connector slightly so it will not be in the way.
  3. Insignia Flex Elite 7.85 Camera  Replacement: stap 3, afbeelding 1 van 1
    • Using a plastic opening tool, pry the camera from the mount.
    • Pry around the perimeter of the camera until it comes free.
    • Be careful, make sure the plastic frame does not break.
  4. Insignia Flex Elite 7.85 Camera  Replacement: stap 4, afbeelding 1 van 2 Insignia Flex Elite 7.85 Camera  Replacement: stap 4, afbeelding 2 van 2
    • The camera should be out of its housing by now. Reinstall new camera.
Conclusie
Antonio Olivieri
401 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S9-G2, Martin Spring 2017 Lid van UMass Dartmouth, Team S9-G2, Martin Spring 2017
UMASSD-MARTIN-S17S9G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 120
