Ga door naar hoofdinhoud
Insignia Flex Elite 7.85 Battery Replacement
Wat je nodig hebt
  1. Insignia Flex Elite 7.85 Battery  Replacement, Battery: stap 1, afbeelding 1 van 2 Insignia Flex Elite 7.85 Battery  Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure the device is turned off before taking it apart to avoid any injuries
    • Use a plastic opening tool to remove the metal backing of the tablet.
    • Insert the plastic opening tool between the screen and metal backing. Use a prying motion to lift the front case from the metal panel.
    • Move the tool around the perimeter of the device until the screen separate.
    • The volume and power button will become free from device when the screen and metal backing are separated. These small pieces are easy to lose, be careful. They’re easy to put back into place when reassembling the tablet.
  2. Insignia Flex Elite 7.85 Battery  Replacement: stap 2, afbeelding 1 van 3 Insignia Flex Elite 7.85 Battery  Replacement: stap 2, afbeelding 2 van 3 Insignia Flex Elite 7.85 Battery  Replacement: stap 2, afbeelding 3 van 3
    • Use a plastic opening tool to free the orange connector ribbon by placing the tool on the connector. Then peal the connector ribbon and bend it backwards so it is not in the way.
  3. Insignia Flex Elite 7.85 Battery  Replacement: stap 3, afbeelding 1 van 2 Insignia Flex Elite 7.85 Battery  Replacement: stap 3, afbeelding 2 van 2
    • Peel back the three pieces of tape circled in the picture.
  4. Insignia Flex Elite 7.85 Battery  Replacement: stap 4, afbeelding 1 van 1
    • Free the battery from the motherboard by prying slightly with the opening tool
  5. Insignia Flex Elite 7.85 Battery  Replacement: stap 5, afbeelding 1 van 1
    • Use the plastic opening tool to remove the battery from the screen.
    • Use a plastic opening tool to gently but firmly pry the battery up along the edges until it is free.
    • Do not bend or puncture the battery or the battery will begin to leak.
    • This step takes the longest. Be careful and do not rush through it. The glue on the back of the battery is difficult to free up.
  6. Insignia Flex Elite 7.85 Battery  Replacement: stap 6, afbeelding 1 van 1
    • The battery should be removed from the tablet. Now replace the battery.
Conclusie
Antonio Olivieri
401 Reputatie
4 handleidingen geschreven
UMass Dartmouth, Team S9-G2, Martin Spring 2017 Lid van UMass Dartmouth, Team S9-G2, Martin Spring 2017
UMASSD-MARTIN-S17S9G2
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 467
