Ga door naar hoofdinhoud
Insignia Flex 7 Battery Replacement
Wat je nodig hebt
  1. Insignia Flex 7 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Insignia Flex 7 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Insignia Flex 7 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Insert the edge of the plastic opener into the grove between the screen and back cover around the perimeter of the device.
    • Then using a gentle prying motion, create a gap large enough to use your fingers to separate the two halves.
  2. Insignia Flex 7 Battery Replacement: stap 2, afbeelding 1 van 2 Insignia Flex 7 Battery Replacement: stap 2, afbeelding 2 van 2
    • Place the tip of the spudger on each side of the battery's electrical connector.
    • Then using a gentle match-striking motion, loosen both sides of the battery's electrical connector.
  3. Insignia Flex 7 Battery Replacement: stap 3, afbeelding 1 van 3 Insignia Flex 7 Battery Replacement: stap 3, afbeelding 2 van 3 Insignia Flex 7 Battery Replacement: stap 3, afbeelding 3 van 3
    • Insert the flat end of the spudger under one side of the battery.
    • Then using a gentle prying and sliding motion, separate the battery from the case. There are two lengthwise strips of glue holding it down.
    • Repeat the process for the other side of the battery.
Conclusie
2 opmerkingen
Link for replacement battery?
Mike - Antwoord
I'm also looking for a replacement battery and i've only found batteries with two cables instead of the 5 this one has
Jose Garza Lozano - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 944
