Ga door naar hoofdinhoud
Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement
Wat je nodig hebt
  1. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 2, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to the edge closest to the screen.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off, work your fingers around the corners and slowly pry the cover off using your fingers.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 4, afbeelding 1 van 3 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 4, afbeelding 2 van 3 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 4, afbeelding 3 van 3
    • Gently remove the black tape from each of the three connectors.
    • It may help to move around the motherboard in a clockwise direction to remove each piece of tape.
  5. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • With a fingernail, gently remove the yellow tape from across the speaker wires.
  6. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Once the pieces of tape are removed the resulting motherboard should look like this picture.
    • The ZIF connectors will be removed in a clockwise motion.
    • Secondly, the ribbon cable connectors will be unplugged to isolate the motherboard.
  7. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 7, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Unplug the smallest ZIF Connector by using you fingernail to flip up the small locking flap. Then safely pull the cable out.
    • Be careful not too pull too hard as the ZIF Connector is fragile and can be damaged easily.
  8. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 8, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Following a clockwise direction, continue unplugging the ZIF connectors by safely puling the cable out.
  9. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the ribbon cables by firstly disconnecting the cable located on the top right of the motherboard,
    • Be careful not to forcefully yank the cable as it could cause a wire to disconnect.
  10. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 10, afbeelding 1 van 1
    • Remove the remaining two bottom ribbon cables.
  11. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 11, afbeelding 1 van 3 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 11, afbeelding 2 van 3 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 11, afbeelding 3 van 3
    • Disconnect the three low profile connectors by using a spudger to prop up both sides. Then, lift the connectors straight up from their sockets.
  12. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 12, afbeelding 1 van 3 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 12, afbeelding 2 van 3 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 12, afbeelding 3 van 3
    • Using a Phillips #2 screwdriver, remove the three 4 mm screws to free the motherboard.
  13. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 13, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 13, afbeelding 2 van 2
    • Pull the two pieces of grey tape off the motherboard.
  14. Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 14, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10W8100 Motherboard Replacement: stap 14, afbeelding 2 van 2
    • Remove the motherboard by lifting it upward.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 13
Altijd: 616
