Ga door naar hoofdinhoud
Insignia Flex 10.1 NS-P10W8100 Battery Replacement
Wat je nodig hebt
  1. Insignia Flex 10.1 NS-P10W8100 Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10W8100 Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Carefully open the laptop and remove the keyboard by disconnecting it.
    • Place keyboard to the side as you will not need it.
    • Beware of plastic clips on the side of the device.
  2. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: stap 2, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: stap 2, afbeelding 2 van 2
    • Lay the screen flat on its surface and use the iFixit opening tool to remove the cover by gently prying the back cover from the screen.
    • Apply the opening tool to the edge closest to the screen.
    • Apply the opening tool to each side which will help pry the back cover evenly.
    • Do not pry on the bottom side of the device. This is the side across from the camera.
  3. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: stap 3, afbeelding 1 van 1
    • Use your fingers and pry the back cover from the screen. You may need to wiggle the cover a bit to separate the pieces.
    • If the back cover does not come off, work your fingers around the corners and slowly pry the cover off using your fingers.
    • Be careful with potential sharp edges and any exposed electrical components.
  4. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: stap 4, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: stap 4, afbeelding 2 van 2
    • Unplug the power supply by disconnecting the red and blue wires found on the motherboard.
  5. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the black tape from the Zero Insertion Force (ZIF) ribbon connector.
  6. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: stap 6, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10W8100 Battery Replacement: stap 6, afbeelding 2 van 2
    • Lift up on the black locking flap, being careful not to damage the surrounding hardware parts.
    • Remove the ZIF ribbon wire by pulling horizontally towards the battery.
  7. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: stap 7, afbeelding 1 van 1
    • Remove the black tape from the small ribbon wire connector.
    • Pull the ribbon connector out of the plug the same way that was mentioned in step 4.
  8. Insignia Flex 10.1 NS-P10W8100 Battery Replacement: stap 8, afbeelding 1 van 1
    • Use the spudger to separate the battery from the base.
    • The battery can be difficult to remove as it is held in with double sided tape.
    • Be sure not to pry on the battery too hard because damage to the screen and/or the battery can occur.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
2 opmerkingen
Very concise and helpful. Thank you
Frank Schaffer - Antwoord
where can i buy the replacement battery?
José Porras - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 28
Altijd: 1,080
