Ga door naar hoofdinhoud
Insignia Flex 10.1 NS-P10A7100 Battery Replacement
Wat je nodig hebt
  1. Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Use the blue iFixit opening tool to remove the backing of the device.
    • Wedge the tool in the crease between the device backing and screen.
  2. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: stap 2, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: stap 2, afbeelding 2 van 2
    • Disconnect the larger ribbon that runs along the top of the battery and connects to the motherboard.
    • Lift up the connector by pulling it up with your fingernail. The ribbon will then be released and you can detach it.
  3. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: stap 3, afbeelding 1 van 2 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: stap 3, afbeelding 2 van 2
    • Detach the five colored wires that connect the battery to the motherboard.
    • Use two fingers and place one on either side of the white plastic encasing the wires.
    • Pull on this piece to release it from the motherboard.
    • Now the battery is detached from the motherboard.
  4. Insignia Flex 10.1 NS-P10A7100 Battery Replacement: stap 4, afbeelding 1 van 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: stap 4, afbeelding 2 van 3 Insignia Flex 10.1 NS-P10A7100 Battery Replacement: stap 4, afbeelding 3 van 3
    • The battery is now only connected to the device by the glue on the bottom.
    • Use the iFixit opening tool to wedge the battery off of the device. You will have to use some force to pry the battery off of the device.
    • Now that your battery is removed it is ready for replacement.
Conclusie
Hannah
289 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 20
Altijd: 974
