Ga door naar hoofdinhoud
Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement
  1. Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement, Rubber Gasket: stap 1, afbeelding 1 van 1
    • Remove lid and place upside down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement: stap 2, afbeelding 1 van 2 Insignia 6-Quart Pressure Cooker Rubber Gasket Replacement: stap 2, afbeelding 2 van 2
    • Grab the edge of the clear rubber gasket and slowly peel it off the lid.
    • Continue peeling off the gasket until it is completely detached from the lid.
Conclusie
Savannah Webb
657 Reputatie
5 handleidingen geschreven
Cal Poly, Team S12-G3, Banghart Winter 2018 Lid van Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Leden
3 opmerkingen
Am having trouble Turning the lid from Unlock to lock. The pin comes out in the back when I go to turn it from unlock to lock. Can you help me?
pclarkrob3 - Antwoord
I bought the insignia pressure cooker at a garage sale but, the rubber gasket smells bad. I’ve cleaned the entire cooker but, that gasket stinks like no other
Chuck Smith - Antwoord
I am having the same problem as the first comment by pclarkrob3 I am having trouble turning the lid from unlock to lock. These are really crappy instructions!!!! I have only used my pressure cooker twice so everything is still new.
Vivian Lang - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 22
Altijd: 1,206
