Ga door naar hoofdinhoud
Insignia 6-Quart Pressure Cooker Float Valve Replacement
  1. Insignia 6-Quart Pressure Cooker Float Valve Replacement, Float Valve: stap 1, afbeelding 1 van 1
    • Remove the lid and place it upside-down on a flat surface.
  2. Insignia 6-Quart Pressure Cooker Float Valve Replacement: stap 2, afbeelding 1 van 1
    • Pinch the rubber gasket on the float valve and pull up.
  3. Insignia 6-Quart Pressure Cooker Float Valve Replacement: stap 3, afbeelding 1 van 2 Insignia 6-Quart Pressure Cooker Float Valve Replacement: stap 3, afbeelding 2 van 2
    • Pull the rubber gasket off of the metal rod.
    • The valve will fall out of its hole onto the table. It can now be cleaned or replaced.
    • You may find it helpful to push up on the float valve from the other side of the lid while you remove the gasket.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Savannah Webb
657 Reputatie
5 handleidingen geschreven
Cal Poly, Team S12-G3, Banghart Winter 2018 Lid van Cal Poly, Team S12-G3, Banghart Winter 2018
CPSU-BANGHART-W18S12G3
4 Leden
2 opmerkingen
I received the replacement valve and pot. Now my insignia instapot won't hold pressure. It keeps seeping steam/spritz out of the float valve. I am ready to toss it in the trash. It worked bafore I replaced that stem. I should've kept it.
Carole Neider - Antwoord
OK after much digging, I found the old valve and now it is pressurizing.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 75
Altijd: 4,371
