Inleiding
Replace a faulty speaker.
Wat je nodig hebt
Using the plastic opening tool, remove screen protector from front of monitor.
Use a heat gun to soften and easily remove epoxy that surrounds the speaker. Gently scrape it free little by little with metal spudger.
3 andere personen hebben deze handleiding voltooid.
5 opmerkingen
Where to purchase the replacement speaker?
Where can we purchase the replacement 8w speaker part
8W Speaker is incorrect.
The speaker needed is 8 Ohm 0.5 Watt.
Thanks for this. Found something on Ali Express, just need to figure out the right size
itryit -
This is good to show how you get it open. Unless you have a speaker that has the plastic piece that connects to the mother board, then it’s useless. The speaker I ordered just had two free standing wires.
