Ga door naar hoofdinhoud
Infant Optics DXR-8 Power Button Replacement
Wat je nodig hebt
  1. Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: stap 1, afbeelding 1 van 3 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: stap 1, afbeelding 2 van 3 Infant Optics DXR-8 Power Button Replacement, Internal Monitor Components: stap 1, afbeelding 3 van 3
    • Using the plastic opening tool, remove screen protector from front of monitor.
  2. Infant Optics DXR-8 Power Button Replacement: stap 2, afbeelding 1 van 3 Infant Optics DXR-8 Power Button Replacement: stap 2, afbeelding 2 van 3 Infant Optics DXR-8 Power Button Replacement: stap 2, afbeelding 3 van 3
    • Remove the six 4mm screws using a Phillips #00 screwdriver.
    • Remove the screen, exposing the circuit board.
    • Turn device over to expose rear circuit board.
  3. Infant Optics DXR-8 Power Button Replacement: stap 3, afbeelding 1 van 3 Infant Optics DXR-8 Power Button Replacement: stap 3, afbeelding 2 van 3 Infant Optics DXR-8 Power Button Replacement: stap 3, afbeelding 3 van 3
    • Disconnect speaker from monitor for ease of access by unplugging wire.
  4. Infant Optics DXR-8 Power Button Replacement, Power Button: stap 4, afbeelding 1 van 1
    • The power button is located at the top of the device.
  5. Infant Optics DXR-8 Power Button Replacement: stap 5, afbeelding 1 van 1
    • Remove the button by picking it up out of the hole it is connected to.
  6. Infant Optics DXR-8 Power Button Replacement: stap 6, afbeelding 1 van 1
    • Insert a new button by placing the small end in the hole to connect the button to the device.
Conclusie
To reassemble your device, follow the instructions in reverse order.
2 opmerkingen
Where did you get the replacement switch?
Dave Peterson - Antwoord
Where can you purchase a new power switch on the circuit board for replacement?
Derrick Silvestri - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 24
Altijd: 4,855
