Inleiding
If the monitor screen isn’t properly displaying images or camera feed from the Infant Optics DXR-8 cameras, it may be time to replace the screen. Follow these instructions to replace the screen in the monitor of the Infant Optics DXR-8.
Wat je nodig hebt
Using the plastic opening tool, remove screen protector from front of monitor.
Using a plastic opening tool, disconnect the ribbon cable connector.
Gently separate the ribbon cable from the motherboard.
Één andere persoon heeft deze handleiding voltooid.
3 opmerkingen
Just completed the screen change, it works great! Thanks so much for this step by step guide.
The screen I ordered came with the metal brackets. Since the base was glued to the motherboard, it took a few extra steps of de-casing the one I got and re-casing onto the board. But worked fine.
I ordered: https://www.amazon.com/dp/B07NYN5PK2?psc...
