Inleiding
The disassembling of the monitor is so to be able to change the screen or replace other components of the monitor.
Wat je nodig hebt
Start by gently inserting the plastic opening tool between the led and casing.
Glide the tool around the entire cover to reveal the screws, which are 5.0 mm.
Remove the four corner screws, 5.0 mm, using a J1 bit.
6 andere personen hebben deze handleiding voltooid.
