Ga door naar hoofdinhoud
India Mark II Foot Valve Replacement
Wat je nodig hebt
  1. India Mark II Foot Valve Replacement, Access Door: stap 1, afbeelding 1 van 2 India Mark II Foot Valve Replacement, Access Door: stap 1, afbeelding 2 van 2
    • Before performing any repairs, perform a water test on the pump by raising and lowering the handle a full 40 strokes. A properly performing pump will yield greater than 10 liters.
    • Remove the hex head bolt from the top of the access door on the pump head.
    • On reassembly, this bolt should be hand-tight.
  2. India Mark II Foot Valve Replacement: stap 2, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 2, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 2, afbeelding 3 van 3
    • Pull the access door straight up off the pump head.
    • Store the access door in a sanitary place to prevent contamination.
  3. India Mark II Foot Valve Replacement: stap 3, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 3, afbeelding 2 van 2
    • The access door has a tongue that fits into the base of the pump head.
    • The access door makes a convenient tray to hold nuts and bolts during the disassembly.
  4. India Mark II Foot Valve Replacement, Chain: stap 4, afbeelding 1 van 3 India Mark II Foot Valve Replacement, Chain: stap 4, afbeelding 2 van 3 India Mark II Foot Valve Replacement, Chain: stap 4, afbeelding 3 van 3
    • Place the spacer collar around the pump rod below the raised chain, with the beveled side down, and the flat side facing up.
  5. India Mark II Foot Valve Replacement: stap 5, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 5, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 5, afbeelding 3 van 3
    • The following procedure requires two people. If you attempt to do this alone, you risk injuring yourself and damaging the pump.
    • Lift the pump handle until the base of the chain comes to rest on the spacer collar, and the chain is slack. Hold the handle in this position while the chain is being detached.
  6. India Mark II Foot Valve Replacement: stap 6, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 6, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 6, afbeelding 3 van 3
    • Using the two access holes, place an angled socket wrench on the bolt and nut attaching the chain to the pump handle.
  7. India Mark II Foot Valve Replacement: stap 7, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 7, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 7, afbeelding 3 van 3
    • Hold the wrench on the bolt stationary.
    • Loosen the nut.
  8. India Mark II Foot Valve Replacement: stap 8, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 8, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 8, afbeelding 3 van 3
    • Remove the nut from the chain bolt.
  9. India Mark II Foot Valve Replacement: stap 9, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 9, afbeelding 2 van 2
    • Remove the washer from the chain bolt.
  10. India Mark II Foot Valve Replacement: stap 10, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 10, afbeelding 2 van 2
    • Remove the chain bolt.
  11. India Mark II Foot Valve Replacement: stap 11, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 11, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 11, afbeelding 3 van 3
    • Pull the top of the chain straight off of the pump handle.
  12. India Mark II Foot Valve Replacement, Head: stap 12, afbeelding 1 van 3 India Mark II Foot Valve Replacement, Head: stap 12, afbeelding 2 van 3 India Mark II Foot Valve Replacement, Head: stap 12, afbeelding 3 van 3
    • Remove the two bolts from the handle side of the pump head.
    • Use one wrench on the bolt and another on the nut beneath. Hold the bolt stationary and loosen the nut.
  13. India Mark II Foot Valve Replacement: stap 13, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 13, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 13, afbeelding 3 van 3
    • Remove the two bolts and nuts from the handle side.
  14. India Mark II Foot Valve Replacement: stap 14, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 14, afbeelding 2 van 2
    • After removing the two handle side bolts, have your partner support the weight of the handle.
    • Remove the two remaining bolts in the same fashion.
  15. India Mark II Foot Valve Replacement: stap 15, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 15, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 15, afbeelding 3 van 3
    • Lift and remove the pump head from the pump.
    • Store the pump head in a sanitary place, preferably above ground, to prevent contamination.
  16. India Mark II Foot Valve Replacement, Chain: stap 16, afbeelding 1 van 2 India Mark II Foot Valve Replacement, Chain: stap 16, afbeelding 2 van 2
    • Slightly twist the head flange, until the corners overhang the top of the tank far enough to grab.
  17. India Mark II Foot Valve Replacement: stap 17, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 17, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 17, afbeelding 3 van 3
    • Lift the head flange up about one foot above the tank.
  18. India Mark II Foot Valve Replacement: stap 18, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 18, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 18, afbeelding 3 van 3
    • Slide the rod clamp around the pump rod, and support it on the tank base.
    • Make sure the pegs in the base of the rod clamp fit into the appropriate holes in the top of the tank.
  19. India Mark II Foot Valve Replacement: stap 19, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 19, afbeelding 2 van 2
    • Tighten the rod clamp against the pump rod.
    • Be sure the pump rod is centered within the jaws of the clamp and held securely.
  20. India Mark II Foot Valve Replacement: stap 20, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 20, afbeelding 2 van 2
    • Lower the head flange.
  21. India Mark II Foot Valve Replacement: stap 21, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 21, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 21, afbeelding 3 van 3
    • Unscrew the chain from the top of the pump rod.
    • Remove the chain.
    • Check the chain for signs of wear or damage.
    • Set the chain in a sanitary place, such as the access door that was previously removed.
  22. India Mark II Foot Valve Replacement, Head Flange: stap 22, afbeelding 1 van 3 India Mark II Foot Valve Replacement, Head Flange: stap 22, afbeelding 2 van 3 India Mark II Foot Valve Replacement, Head Flange: stap 22, afbeelding 3 van 3
    • Remove the chain support from around the pump rod.
  23. India Mark II Foot Valve Replacement: stap 23, afbeelding 1 van 1
    • Remove the jam nut from the top of the pump rod.
  24. India Mark II Foot Valve Replacement: stap 24, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 24, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 24, afbeelding 3 van 3
    • Remove the head flange.
  25. India Mark II Foot Valve Replacement: stap 25, afbeelding 1 van 1
    • Screw the jam nut back onto the top of the pump rod.
  26. India Mark II Foot Valve Replacement, Riser Main Coupling: stap 26, afbeelding 1 van 2 India Mark II Foot Valve Replacement, Riser Main Coupling: stap 26, afbeelding 2 van 2
    • Place a coupling over the pump rod, on top of the rod vise.
  27. India Mark II Foot Valve Replacement: stap 27, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 27, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 27, afbeelding 3 van 3
    • Reattach the T-handle to the top of the pump rod.
  28. India Mark II Foot Valve Replacement: stap 28, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 28, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 28, afbeelding 3 van 3
    • Loosen and remove the rod vise from the pump rod.
    • The coupling will drop down onto the riser main.
  29. India Mark II Foot Valve Replacement: stap 29, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 29, afbeelding 2 van 2
    • Screw the coupling onto the end of the riser main.
    • Use a pipe wrench to tighten the coupling onto the riser main.
  30. India Mark II Foot Valve Replacement, Riser Main: stap 30, afbeelding 1 van 1
    • When using the lifting arms, it is essential that each arm have a gap above and below it, and that the openings alternate direction up the pipe.
    • Set the first lifting arm just above (but not touching) the pipe vise.
  31. India Mark II Foot Valve Replacement: stap 31, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 31, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 31, afbeelding 3 van 3
    • Add the other two lifting arms.
    • Ensure three things about the arms:
    • They must be equally spaced around the riser main (120° apart).
    • The arms must not touch each other, the coupling at the top, or the pipe vise at the bottom.
    • The openings should alternate, to keep the riser main secure.
  32. India Mark II Foot Valve Replacement: stap 32, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 32, afbeelding 2 van 2
    • Communication is very important throughout this procedure.
    • As each person lifts up on their lifting spanner, they announce "got it" to let everyone else know they're holding.
    • Once all three lifters have announced that they've "got it," loosen the vise.
  33. India Mark II Foot Valve Replacement: stap 33, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 33, afbeelding 2 van 2
    • With the vise loosened, lift up the riser main 1-2 feet.
    • Lift only as high as everyone is comfortable.
  34. India Mark II Foot Valve Replacement: stap 34, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 34, afbeelding 2 van 2
    • Tighten the pipe vise, with the following procedure:
    • Announce "tightening."
    • Tighten the vise.
    • Announce "Tight."
  35. India Mark II Foot Valve Replacement: stap 35, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 35, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 35, afbeelding 3 van 3
    • Slide the three lifting spanners down on the riser main, into new lifting positions.
    • Again, make sure he lifting spanners don't touch anything above or below, and that they are evenly spaced about the pipe.
  36. India Mark II Foot Valve Replacement: stap 36, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 36, afbeelding 2 van 2
    • Once all of the lifters have said "got it," loosen the pipe vise.
  37. India Mark II Foot Valve Replacement: stap 37, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 37, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 37, afbeelding 3 van 3
    • Lift the riser main another 1-2 feet.
  38. India Mark II Foot Valve Replacement: stap 38, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 38, afbeelding 2 van 2
    • Tighten the pipe vise, following the same verbal procedure.
    • Repeat the procedure several times:
    • Once everyone is securely holding the pipe, loosen the pipe vise.
    • Lift the pipe.
    • Tighten the pipe vise.
    • Slide the lifting spanners down to a new position.
  39. India Mark II Foot Valve Replacement: stap 39, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 39, afbeelding 2 van 2
    • At ten feet, you will reach the first coupling in the riser main.
    • While the three lifters are holding the riser main, the vise operator must open the vise wide enough to let the coupling pass through the jaws.
  40. India Mark II Foot Valve Replacement: stap 40, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 40, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 40, afbeelding 3 van 3
    • Lift the riser main up through the pipe vise, until the coupling clears the jaws.
    • Tighten the pipe vise and move the lifting spanners down to a new position.
  41. India Mark II Foot Valve Replacement: stap 41, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 41, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 41, afbeelding 3 van 3
    • Lift the riser main high enough that there is room beneath the coupling for the three lifting spanners.
  42. India Mark II Foot Valve Replacement: stap 42, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 42, afbeelding 2 van 2
    • Use a pipe vise to unscrew the first section of riser main from the coupling.
    • Be careful not to remove the coupling from the lower section of riser main. You may need to use two pipe wrenches to hold the coupling still while you loosen the top section of riser main.
  43. India Mark II Foot Valve Replacement: stap 43, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 43, afbeelding 2 van 2
    • Unscrew the upper section of riser main from the coupling.
    • Be careful—the pipe will likely be full of water, that will leak out above the coupling as you unscrew the pipe.
  44. India Mark II Foot Valve Replacement: stap 44, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 44, afbeelding 2 van 2
    • Lift the section of pipe straight up from the coupling.
    • Be very careful to hold the pipe as straight up as possible. If it bends or falls over, it may damage the pump rod, or injure someone. Always have at least two people holding the pipe.
  45. India Mark II Foot Valve Replacement: stap 45, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 45, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 45, afbeelding 3 van 3
    • Place the rod vise on the pump rod between the section of riser main.
    • Tighten the rod vise on the pump rod.
  46. India Mark II Foot Valve Replacement: stap 46, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 46, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 46, afbeelding 3 van 3
    • Use two wrenches to disconnect the upper section of pump rod from the lower section.
    • Hold the lower section stationary and rotate the upper section.
    • Once detached, lift and remove the upper sections of riser main and pump rod together, and set them down.
  47. India Mark II Foot Valve Replacement: stap 47, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 47, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 47, afbeelding 3 van 3
    • Remove the T-handle from the top of the pump rod.
  48. India Mark II Foot Valve Replacement: stap 48, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 48, afbeelding 2 van 2
    • Screw the T-handle onto the newly exposed top of the pump rod.
  49. India Mark II Foot Valve Replacement: stap 49, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 49, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 49, afbeelding 3 van 3
    • Loosen and remove the rod vise.
    • Repeat the lifting procedure for the remaining sections of riser main and pump rod.
  50. India Mark II Foot Valve Replacement, Cylinder: stap 50, afbeelding 1 van 1
    • The last section of riser main pipe will have the pump cylinder attached to the bottom.
    • Pull the assembly of riser main pipe and cylinder out of the well and set the assembly on a block of wood to keep the cylinder off the ground.
  51. India Mark II Foot Valve Replacement: stap 51, afbeelding 1 van 3 India Mark II Foot Valve Replacement: stap 51, afbeelding 2 van 3 India Mark II Foot Valve Replacement: stap 51, afbeelding 3 van 3
    • Using two pipe wrenches, unscrew the cylinder from the riser main.
  52. India Mark II Foot Valve Replacement: stap 52, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 52, afbeelding 2 van 2
    • Slowly pull the cylinder off of the pump rod, exposing the traveling valve and foot valve.
  53. India Mark II Foot Valve Replacement, Foot Valve: stap 53, afbeelding 1 van 3 India Mark II Foot Valve Replacement, Foot Valve: stap 53, afbeelding 2 van 3 India Mark II Foot Valve Replacement, Foot Valve: stap 53, afbeelding 3 van 3
    • Using two pipe wrenches, remove the end cap from the cylinder.
  54. India Mark II Foot Valve Replacement: stap 54, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 54, afbeelding 2 van 2
    • Remove the foot valve from the end cap.
    • Take note of the direction of the foot valve in the end cap. This is extremely important for reassembly, as the pump will not work if the valve is facing the wrong direction.
  55. India Mark II Foot Valve Replacement: stap 55, afbeelding 1 van 2 India Mark II Foot Valve Replacement: stap 55, afbeelding 2 van 2
    • Check the foot valve components for signs of wear.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Andrew Optimus Goldheart
502.810 Reputatie
407 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.817 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 33
Altijd: 746
