Inleiding
This guide shows how to open up the projector. This will allow for following actions to replace parts.
Wat je nodig hebt
Flip the projector on its back.
Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
Één andere persoon heeft deze handleiding voltooid.
1Gids Commentaar
There’s a 4th orange screw to be removed on the STEP1 image. It’s located on the top right corner of the projector body, if looking at it as shown on the photo...STEP4 image - all 3 plastic latches at the top panel are damaged. That’s why at the shown case, the front panel goes off easily.If the projector has never been opened, it is actually very hard to remove the front panel. One can release the latches with thin tea spoon (f.ex.), operating it with caution, over the front grill.
