Ga door naar hoofdinhoud
InFocus Screenplay 4805 Top Panel Replacement
Wat je nodig hebt
  1. InFocus Screenplay 4805 Top Panel Replacement, Top Panel: stap 1, afbeelding 1 van 3 InFocus Screenplay 4805 Top Panel Replacement, Top Panel: stap 1, afbeelding 2 van 3 InFocus Screenplay 4805 Top Panel Replacement, Top Panel: stap 1, afbeelding 3 van 3
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
  2. InFocus Screenplay 4805 Top Panel Replacement: stap 2, afbeelding 1 van 2 InFocus Screenplay 4805 Top Panel Replacement: stap 2, afbeelding 2 van 2
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
  3. InFocus Screenplay 4805 Top Panel Replacement: stap 3, afbeelding 1 van 3 InFocus Screenplay 4805 Top Panel Replacement: stap 3, afbeelding 2 van 3 InFocus Screenplay 4805 Top Panel Replacement: stap 3, afbeelding 3 van 3
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
  4. InFocus Screenplay 4805 Top Panel Replacement: stap 4, afbeelding 1 van 1
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
  5. InFocus Screenplay 4805 Top Panel Replacement: stap 5, afbeelding 1 van 1
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
There’s a 4th orange screw to be removed on the STEP1 image. It’s located on the top right corner of the projector body, if looking at it as shown on the photo...STEP4 image - all 3 plastic latches at the top panel are damaged. That’s why at the shown case, the front panel goes off easily.If the projector has never been opened, it is actually very hard to remove the front panel. One can release the latches with thin tea spoon (f.ex.), operating it with caution, over the front grill.
madyogi - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 303
