Ga door naar hoofdinhoud
InFocus Screenplay 4805 Mono Speaker Replacement
Wat je nodig hebt
  1. InFocus Screenplay 4805 Mono Speaker Replacement, Top Panel: stap 1, afbeelding 1 van 3 InFocus Screenplay 4805 Mono Speaker Replacement, Top Panel: stap 1, afbeelding 2 van 3 InFocus Screenplay 4805 Mono Speaker Replacement, Top Panel: stap 1, afbeelding 3 van 3
    • Flip the projector on its back.
    • Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
    • Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
  2. InFocus Screenplay 4805 Mono Speaker Replacement: stap 2, afbeelding 1 van 2 InFocus Screenplay 4805 Mono Speaker Replacement: stap 2, afbeelding 2 van 2
    • Turn the projector, facing the back cable board towards you.
    • Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
    • Gently take off back cable panel.
  3. InFocus Screenplay 4805 Mono Speaker Replacement: stap 3, afbeelding 1 van 3 InFocus Screenplay 4805 Mono Speaker Replacement: stap 3, afbeelding 2 van 3 InFocus Screenplay 4805 Mono Speaker Replacement: stap 3, afbeelding 3 van 3
    • Turn the projector so the front side with the lens is facing you.
    • Gently pry the both of the grey lens rings using the metal spudger.
  4. InFocus Screenplay 4805 Mono Speaker Replacement: stap 4, afbeelding 1 van 1
    • Now that the screws have been removed, proceed with the removal of the outer panel.
    • Gently remove the front lens panel.
    • Be forewarned, the panel will resist. Be careful not to break the lens.
  5. InFocus Screenplay 4805 Mono Speaker Replacement: stap 5, afbeelding 1 van 1
    • Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
    • Rest the lid behind the projector so the insides are exposed and undamaged.
  6. InFocus Screenplay 4805 Mono Speaker Replacement, Mono Speaker: stap 6, afbeelding 1 van 2 InFocus Screenplay 4805 Mono Speaker Replacement, Mono Speaker: stap 6, afbeelding 2 van 2
    • Locate the circle speaker on the lower left corner of the inside of the lid.
    • Use the Phillips #1 screwdriver to remove the three gold 2cm gold screws.
    • Remove the speaker from the lid and flip metallic side down.
  7. InFocus Screenplay 4805 Mono Speaker Replacement: stap 7, afbeelding 1 van 2 InFocus Screenplay 4805 Mono Speaker Replacement: stap 7, afbeelding 2 van 2
    • Gently pull the white connector to release the speaker.
    • Lift the speaker out of its holding.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 164
