Ga door naar hoofdinhoud
InFocus LP540 Projector Main Board Replacement
Wat je nodig hebt
  1. InFocus LP540 Projector Main Board Replacement, Main Board: stap 1, afbeelding 1 van 3 InFocus LP540 Projector Main Board Replacement, Main Board: stap 1, afbeelding 2 van 3 InFocus LP540 Projector Main Board Replacement, Main Board: stap 1, afbeelding 3 van 3
    • Flip the projector right-side up and turn it so that the back ports are facing you.
    • Remove the 7 mm metallic screws using the flat-head screwdriver.
    • Using the T10 Torx screwdriver, remove the two black 10 mm screws located at the center of the back panel.
  2. InFocus LP540 Projector Main Board Replacement: stap 2, afbeelding 1 van 2 InFocus LP540 Projector Main Board Replacement: stap 2, afbeelding 2 van 2
    • Flip the projector over.
    • Use the T10 Torx screwdriver head to remove the two 77mm screws located nearest to the back panel ports.
    • Remove the two 10mm screws located near the lens side with the T10 Torx screwdriver head.
    • Flip the projector back over.
    • Lift up the main lid cautiously to avoid ripping the electrical ribbons.
  3. InFocus LP540 Projector Main Board Replacement: stap 3, afbeelding 1 van 3 InFocus LP540 Projector Main Board Replacement: stap 3, afbeelding 2 van 3 InFocus LP540 Projector Main Board Replacement: stap 3, afbeelding 3 van 3
    • Unplug the speaker wire from the circuit board by simultaneously squeezing the sides and pulling.
    • Pull on the brown tabs located at the sides of the white plastic ribbon holder and pull the ribbon out.
    • Remove the top cover.
  4. InFocus LP540 Projector Main Board Replacement: stap 4, afbeelding 1 van 2 InFocus LP540 Projector Main Board Replacement: stap 4, afbeelding 2 van 2
    • Hold down the release tabs to remove the cables from the white tabs.
  5. InFocus LP540 Projector Main Board Replacement: stap 5, afbeelding 1 van 3 InFocus LP540 Projector Main Board Replacement: stap 5, afbeelding 2 van 3 InFocus LP540 Projector Main Board Replacement: stap 5, afbeelding 3 van 3
    • Use the T10 Torx screwdriver to remove the five 5mm screws located throughout the motherboard.
    • Pull up the five metal tabs located at the rear of the projector.
    • Do not pull up on the metal tabs too hard or too fast because they can break easily.
  6. InFocus LP540 Projector Main Board Replacement: stap 6, afbeelding 1 van 3 InFocus LP540 Projector Main Board Replacement: stap 6, afbeelding 2 van 3 InFocus LP540 Projector Main Board Replacement: stap 6, afbeelding 3 van 3
    • Remove the three gold ribbons by flipping up the black taps that hold the ribbon in place.
    • Pull the ribbons out carefully and place them under the main board.
    • Carefully lift the entire main board up.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jorge L Navarro
533 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-17, Regan Winter 2014 Lid van Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 24
Altijd: 2,165
