Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Place the projector on its back with the control buttons facing down.
Remove the black 7mm screw on the external case with a Phillips 2 screwdriver.
Remove the 7mm screw near the bottom center with a Philips 2 screwdriver head.
Loosen but do not remove the 7mm screw near the upper right corner with the Phillips 2 screwdriver head.
Grab the silver handle.
Unhook the handle so it can move freely.
Pull the handle straight up until the lamp is completely removed from projector.
Één andere persoon heeft deze handleiding voltooid.
