Ga door naar hoofdinhoud
Inleiding
This guide will assist with replacing a non-functioning projector lamp, which is responsible for providing the light necessary for projection.
Onderdelen
Geen onderdelen opgegeven.
  1. Place the projector on its back with the control buttons facing down. Remove the black  7mm screw on the external case with a Phillips 2 screwdriver.
    • Place the projector on its back with the control buttons facing down.
    • Remove the black 7mm screw on the external case with a Phillips 2 screwdriver.
  2. Use the plastic flat-head to remove the lamp lid.
    • Use the plastic flat-head to remove the lamp lid.
  3. Remove the 7mm screw near the bottom center with a Philips 2 screwdriver head. Loosen but do not remove the 7mm screw near the upper right corner with the Phillips 2 screwdriver head.
    • Remove the 7mm screw near the bottom center with a Philips 2 screwdriver head.
    • Loosen but do not remove the 7mm screw near the upper right corner with the Phillips 2 screwdriver head.
  4. Grab the silver handle. Unhook the handle so it can move freely. Pull the handle straight up until the lamp is completely removed from projector.
    • Grab the silver handle.
    • Unhook the handle so it can move freely.
    • Pull the handle straight up until the lamp is completely removed from projector.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jorge L Navarro
533 Reputatie
5 handleidingen geschreven
Cal Poly, Team 13-17, Regan Winter 2014 Lid van Cal Poly, Team 13-17, Regan Winter 2014
CPSU-REGAN-W14S13G17
6 Leden
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 18
Altijd: 2,643
