Ga door naar hoofdinhoud
InFocus IN3114 Fans Replacement
Wat je nodig hebt
  1. InFocus IN3114 Fans Replacement, Top Plate: stap 1, afbeelding 1 van 2 InFocus IN3114 Fans Replacement, Top Plate: stap 1, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the 1.2 cm Phillips-head screw from each side of the projector.
  2. InFocus IN3114 Fans Replacement: stap 2, afbeelding 1 van 3 InFocus IN3114 Fans Replacement: stap 2, afbeelding 2 van 3 InFocus IN3114 Fans Replacement: stap 2, afbeelding 3 van 3
    • Use your hands to slide the top plate off of the projector.
    • Lift and remove the plate.
  3. InFocus IN3114 Fans Replacement, Lamp: stap 3, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to unscrew the two 9 mm screws on the top of the lamp housing unit.
    • Screws will not come all the way out. It is best to just loosen them as much as possible.
  4. InFocus IN3114 Fans Replacement: stap 4, afbeelding 1 van 1
    • Use your hands to pull up on the silver handle and remove the lamp housing unit.
  5. InFocus IN3114 Fans Replacement: stap 5, afbeelding 1 van 2 InFocus IN3114 Fans Replacement: stap 5, afbeelding 2 van 2
    • Once the lamp housing is removed flip it over where silver pull tab is face down.
    • Use a Phillips #00 screwdriver to remove the 5 mm screw from the right side of the lamp housing unit.
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws from the top of the unit.
  6. InFocus IN3114 Fans Replacement: stap 6, afbeelding 1 van 1
    • Use hands to pull off the black unit cover.
  7. InFocus IN3114 Fans Replacement: stap 7, afbeelding 1 van 2 InFocus IN3114 Fans Replacement: stap 7, afbeelding 2 van 2
    • Once the cover is removed, flip the housing unit so the bulb is face down.
    • Remove the four 4 mm screws with a Phillips #00 screwdriver.
  8. InFocus IN3114 Fans Replacement: stap 8, afbeelding 1 van 2 InFocus IN3114 Fans Replacement: stap 8, afbeelding 2 van 2
    • Use hands to pull out the bulb and silver cover.
    • Gently pull on the two wires that connect the bulb to its housing to disconnect them.
  9. InFocus IN3114 Fans Replacement: stap 9, afbeelding 1 van 2 InFocus IN3114 Fans Replacement: stap 9, afbeelding 2 van 2
    • Once wires are disconnected, Remove the bulb from the silver cover and replace.
  10. InFocus IN3114 Fans Replacement, Fans: stap 10, afbeelding 1 van 1
    • Use a Phillips #1 screwdriver to loosen and remove the five 7 mm screws that secure the frame.
  11. InFocus IN3114 Fans Replacement: stap 11, afbeelding 1 van 1
    • Pull back the top of the front face slightly.
    • Use a Phillips #1 screwdriver to remove the two 7 mm screws, and lift upwards.
    • These screws are held in tightly. In order to prevent stripping, be sure to apply ample downward pressure to the screwdriver when unscrewing the screws.
  12. InFocus IN3114 Fans Replacement: stap 12, afbeelding 1 van 2 InFocus IN3114 Fans Replacement: stap 12, afbeelding 2 van 2
    • Use hands to unplug wiring connecting the front face to the main projector.
    • Wiring should pull out with moderate force.
  13. InFocus IN3114 Fans Replacement: stap 13, afbeelding 1 van 1
    • Carefully pull the left vent back, and use a Phillips #1 screwdriver to remove the screws that secure it in place.
    • These screws are held in tightly. In order to prevent stripping, be sure to apply ample downward pressure.
  14. InFocus IN3114 Fans Replacement: stap 14, afbeelding 1 van 3 InFocus IN3114 Fans Replacement: stap 14, afbeelding 2 van 3 InFocus IN3114 Fans Replacement: stap 14, afbeelding 3 van 3
    • Carefully remove each fan, and use your hands to gently unplug their connectors from the circuit board.
    • The wires should unplug easily with a moderate tug.
Conclusie
Isaac Sherman
221 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 21
Altijd: 433
