Inleiding
This Metal Cover needs to be removed in order to replace most parts in the device.
Wat je nodig hebt
Turn the projector so that the lens is facing you.
Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
Remove the service cover.
Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
Lift up the metal cover and set it aside to reveal the motherboard.
Bijna klaar!
Conclusie
