Ga door naar hoofdinhoud
InFocus IN3104 Lamp Replacement
Wat je nodig hebt
  1. InFocus IN3104 Lamp Replacement, Top Cover: stap 1, afbeelding 1 van 3 InFocus IN3104 Lamp Replacement, Top Cover: stap 1, afbeelding 2 van 3 InFocus IN3104 Lamp Replacement, Top Cover: stap 1, afbeelding 3 van 3
    • Turn the projector so that the lens is facing you.
    • On the left side of the projector, there is a screw and a knob inside of the small grate.
    • Use a Phillips #1 screwdriver to remove the 6 mm screw that secures top cover.
    • Remove the service cover.
  2. InFocus IN3104 Lamp Replacement: stap 2, afbeelding 1 van 3 InFocus IN3104 Lamp Replacement: stap 2, afbeelding 2 van 3 InFocus IN3104 Lamp Replacement: stap 2, afbeelding 3 van 3
    • Use a Phillips #1 screwdriver to remove the seven 6 mm screws.
    • Use a Phillips #1 screwdriver to remove the two 5 mm screws.
    • Remove the top cover.
    • Do not pull the cover too hard. It may damage the wire that is connected to the motherboard.
  3. InFocus IN3104 Lamp Replacement, InFocus IN3104 Metal Cover Disassembly: stap 3, afbeelding 1 van 2 InFocus IN3104 Lamp Replacement, InFocus IN3104 Metal Cover Disassembly: stap 3, afbeelding 2 van 2
    • Use a Phillips #1 screwdriver to remove the nine 6 mm screws.
    • Lift up the metal cover and set it aside to reveal the motherboard.
  4. InFocus IN3104 Lamp Replacement: stap 4, afbeelding 1 van 3 InFocus IN3104 Lamp Replacement: stap 4, afbeelding 2 van 3 InFocus IN3104 Lamp Replacement: stap 4, afbeelding 3 van 3
    • Carefully pry up the black plastic locking bar of the ZIF connector on the motherboard with a plastic spudger.
    • Pull out the blue-tipped, white ribbon cable from the connector.
    • Remove the metal cover.
  5. InFocus IN3104 Lamp Replacement, Lamp: stap 5, afbeelding 1 van 3 InFocus IN3104 Lamp Replacement, Lamp: stap 5, afbeelding 2 van 3 InFocus IN3104 Lamp Replacement, Lamp: stap 5, afbeelding 3 van 3
    • Use a Phillips #0 screwdriver to remove the four 6 mm screws.
    • You may need to use a flexible extender to help remove the screws easily.
  6. InFocus IN3104 Lamp Replacement: stap 6, afbeelding 1 van 3 InFocus IN3104 Lamp Replacement: stap 6, afbeelding 2 van 3 InFocus IN3104 Lamp Replacement: stap 6, afbeelding 3 van 3
    • Remove the lamp power cable situated beside the lamp by pulling it straight out.
    • Remove the lamp by pulling it straight out from the device.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 663
