Inleiding
After a few months blending smoothies, the Impuls blender stopped working. We knew this might be the end of this cheap blender and tend to buy a new one. However fixing the blender is even cheaper than buying a new one and makes you feel good. That is why we started opening the blender and get to the inside to be able to use it again.
Wat je nodig hebt
Here you see the Impuls blender
First, seperate the the blender jar from the bottom part by turning it and put it aside.
If you will use a shrink sleeve to cover the electronic wire, it has to be put on the wire first. Otherwise if electrical tape is used, this can be done afterwards.
Solder the two wires with a soldering iron.
Shrink the sleeve with a heater or put the electrical tape around the soldered wire.
To reassemble your device, follow the instructions in reverse order.
Één andere persoon heeft deze handleiding voltooid.
