Ga door naar hoofdinhoud
Impression i7 Front Camera Replacement
Wat je nodig hebt
  1. Impression i7 Front Camera Replacement, Battery: stap 1, afbeelding 1 van 1
    • Wedge the plastic opening tool into the seam nearest to the screen surface and begin to pry off the back of the device.
  2. Impression i7 Front Camera Replacement: stap 2, afbeelding 1 van 1
    • Move the plastic opening tool along the perimeter of the device, loosening the entire back as you go.
  3. Impression i7 Front Camera Replacement: stap 3, afbeelding 1 van 1
    • After the entire perimeter has been pried, remove the back of the device.
    • Be careful not to disconnect the speaker and microphone cables attached to the back of the tablet.
  4. Impression i7 Front Camera Replacement: stap 4, afbeelding 1 van 2 Impression i7 Front Camera Replacement: stap 4, afbeelding 2 van 2
    • Remove the transparent, orange tape from the edge of the battery.
    • Pry the battery off, using the plastic opening tool.
  5. Impression i7 Front Camera Replacement: stap 5, afbeelding 1 van 1
    • Desolder the positive and negative leads.
  6. Impression i7 Front Camera Replacement: stap 6, afbeelding 1 van 2 Impression i7 Front Camera Replacement: stap 6, afbeelding 2 van 2
    • Pull the battery away from the adhesive.
    • Peel the gray tape from the top of the battery.
  7. Impression i7 Front Camera Replacement, Front Camera: stap 7, afbeelding 1 van 1
    • Gently pull the front camera connection out of its socket.
  8. Impression i7 Front Camera Replacement: stap 8, afbeelding 1 van 1
    • Lift the camera unit from its housing. The unit should come out with minimal force.
Conclusie
Cole Beaver
390 Reputatie
3 handleidingen geschreven
IUPUI, Team S1-G5, Baechle Fall 2018 Lid van IUPUI, Team S1-G5, Baechle Fall 2018
IUPUI-BAECHLE-F18S1G5
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 4
Altijd: 91
