Ga door naar hoofdinhoud
Imation Superdisk USB Drive Disc Drive Casing Replacement
Wat je nodig hebt
  1. Imation Superdisk USB Drive Disc Drive Casing Replacement, Plastic Housing: stap 1, afbeelding 1 van 2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Plastic Housing: stap 1, afbeelding 2 van 2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 2, afbeelding 1 van 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 2, afbeelding 2 van 2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 3, afbeelding 1 van 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 3, afbeelding 2 van 2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 4, afbeelding 1 van 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 4, afbeelding 2 van 2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 5, afbeelding 1 van 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 5, afbeelding 2 van 2
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 6, afbeelding 1 van 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 6, afbeelding 2 van 2
    • Slide the metal housing out of the plastic shell.
  7. Imation Superdisk USB Drive Disc Drive Casing Replacement, Metal Casing: stap 7, afbeelding 1 van 2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Metal Casing: stap 7, afbeelding 2 van 2
    • Slide metal panel out of the metal casing.
  8. Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 8, afbeelding 1 van 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 8, afbeelding 2 van 2
    • Slide disk drive out of metal casing.
  9. Imation Superdisk USB Drive Disc Drive Casing Replacement, Daughter Board: stap 9, afbeelding 1 van 1
    • Flip the disk drive over so the the plug on the daughter board is visible.
  10. Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 10, afbeelding 1 van 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 10, afbeelding 2 van 2
    • Using an iPod opener put pressure on the white plug and pull backwards until the daughter board unplugs from the main unit.
  11. Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 11, afbeelding 1 van 2 Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 11, afbeelding 2 van 2
    • Gently pull on the daughter board until it separates from the device.
  12. Imation Superdisk USB Drive Disc Drive Casing Replacement, Disc Drive Casing: stap 12, afbeelding 1 van 2 Imation Superdisk USB Drive Disc Drive Casing Replacement, Disc Drive Casing: stap 12, afbeelding 2 van 2
    • Place a plastic spudger in between the disk drive and its metal casing. Use the spudger as a lever the until the metal casing detaches from the disk drive.
    • You may have to use the plastic spudger in several spots along the metal casing.
  13. Imation Superdisk USB Drive Disc Drive Casing Replacement: stap 13, afbeelding 1 van 1
    • lift the disk drive completely out of the metal casing and set it aside.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Caitlin Horwatt
137 Reputatie
2 handleidingen geschreven
Ohio State, Team 1-2, Buehl Spring 2014 Lid van Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Leden
14 handleidingen geschreven
Één opmerking
Does anyone know if the MAC USB version works on modern PCs?
davidpaulpeterson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 9
Altijd: 576
