Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Flip the device over so the bottom is facing up.
You will know it is the bottom because there will be six silver screws visible.
Flip the disk drive over so the the plug on the daughter board is visible.
Place a plastic spudger in between the disk drive and its metal casing. Use the spudger as a lever the until the metal casing detaches from the disk drive.
Één andere persoon heeft deze handleiding voltooid.
Één commentaar
Does anyone know if the MAC USB version works on modern PCs?
