Inleiding
This guide describes how to replace a compressor relay in the Igloo Mini Fridge IRF32BK. This can be very important, as a faulty compressor relay can affect the cooling, which can lead to many food items going bad. Before following this guide, make sure your fridge is unplugged from the socket, as leaving it plugged in can cause an electrical shock once you start replacing the compressor relay. Furthermore, use caution when dealing with the knife. Use the knife incorrectly can lead to unnecessary damage that might be irreversible.
Wat je nodig hebt
Clear out all food products in the refrigerator.
Unplug the plug from the outlet.
Turn the refrigerator backward.
5 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Would you happen to know the part numbers for the start relay and overload on this mini fridge that you are working on in this tutorial?
