Tools
Parts
No parts specified.
This step is untranslated. Help translate it
Insert a plastic opening tool in the seam between the keyboard and laptop body.
Carefully run the tool around the top and sides of the keyboard to pop out the 9 tabs holding in the keyboard.
Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests.
Locate the ribbon cable connecting the keyboard to the motherboard.
Use the tip of the opening tool to lift the black flap on the connector.
With the twezers, gently lift the ribbon cable out of the connector.
Ensure the cutouts on the end of the cable match the tabs on the connector.
4 other people completed this guide.
2 Comments
Unfortunately my ribbon cable connector lock snapped and I'm having trouble ensuring all connector ports are established. Tried using electrical tape but doesn't seem to work. Be grateful for any advice
