Ga door naar hoofdinhoud
IdeaPad Yoga 13 Keyboard Replacement
Wat je nodig hebt
  1. IdeaPad Yoga 13 Keyboard Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Power off your laptop before beginning disassembly.
    • Open the laptop to locate the keyboard.
  2. IdeaPad Yoga 13 Keyboard Replacement: stap 2, afbeelding 1 van 2 IdeaPad Yoga 13 Keyboard Replacement: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool in the seam between the keyboard and laptop body.
    • Carefully run the tool around the top and sides of the keyboard to pop out the 9 tabs holding in the keyboard.
  3. IdeaPad Yoga 13 Keyboard Replacement: stap 3, afbeelding 1 van 3 IdeaPad Yoga 13 Keyboard Replacement: stap 3, afbeelding 2 van 3 IdeaPad Yoga 13 Keyboard Replacement: stap 3, afbeelding 3 van 3
    • Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests.
    • Be careful when lifting the keyboard up. The ribbon cable connecting it to the motherboard is very short, and the connector is fragile.
    • The top corners of the keyboard may be stuck to the laptop bezel with double sided tape. See rectangles in Image 3. Be careful as you lift the keyboard up and pivot it toward you.
  4. IdeaPad Yoga 13 Keyboard Replacement: stap 4, afbeelding 1 van 3 IdeaPad Yoga 13 Keyboard Replacement: stap 4, afbeelding 2 van 3 IdeaPad Yoga 13 Keyboard Replacement: stap 4, afbeelding 3 van 3
    • Locate the ribbon cable connecting the keyboard to the motherboard.
    • Use the tip of the opening tool to lift the black flap on the connector.
    • With the twezers, gently lift the ribbon cable out of the connector.
    • Be careful when reinserting the ribbon cable.
    • Ensure the cutouts on the end of the cable match the tabs on the connector.
Conclusie
4 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Best tutorial for Lenovo Yoga 13 keyboard replacement !
Saved my Yoga 13 . Thanks a lot.
djibe - Antwoord
Unfortunately my ribbon cable connector lock snapped and I'm having trouble ensuring all connector ports are established. Tried using electrical tape but doesn't seem to work. Be grateful for any advice
robbarry89 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 25
Altijd: 8,296
