Ga door naar hoofdinhoud
IdeaPad Yoga 13 Charging Port Replacement
Wat je nodig hebt
  1. IdeaPad Yoga 13 Charging Port Replacement, Charging Port: stap 1, afbeelding 1 van 1
    • Remove all ten screws using the T4 Torx screwdriver.
    • Remove the back cover from the device.
  2. IdeaPad Yoga 13 Charging Port Replacement: stap 2, afbeelding 1 van 2 IdeaPad Yoga 13 Charging Port Replacement: stap 2, afbeelding 2 van 2
    • Use the blue opening tool to further separate the keyboard bezel.
    • Carefully apply pressure to the keyboard. It should easily pop out.
  3. IdeaPad Yoga 13 Charging Port Replacement: stap 3, afbeelding 1 van 1
    • To remove the keyboard bezel, unscrew and remove the five screws using the Phillips #0 screwdriver.
  4. IdeaPad Yoga 13 Charging Port Replacement: stap 4, afbeelding 1 van 2 IdeaPad Yoga 13 Charging Port Replacement: stap 4, afbeelding 2 van 2
    • Unplug the connections from the motherboard.
    • There is a different connection for the mouse and keyboard.
  5. IdeaPad Yoga 13 Charging Port Replacement: stap 5, afbeelding 1 van 1
    • Remove the outer bezel to reveal the entire internal layout of the computer.
    • Motherboard and other internal components are now exposed.
  6. IdeaPad Yoga 13 Charging Port Replacement: stap 6, afbeelding 1 van 3 IdeaPad Yoga 13 Charging Port Replacement: stap 6, afbeelding 2 van 3 IdeaPad Yoga 13 Charging Port Replacement: stap 6, afbeelding 3 van 3
    • Remove charging port by prying out the yellow port from the computer chassis.
    • Note the route of the cable for re-installation of the replacement.
Conclusie
Kaitlyn Johnson
157 Reputatie
1 Handleiding geschreven
IUPUI, Team S1-G2, Harley Spring 2019 Lid van IUPUI, Team S1-G2, Harley Spring 2019
IUPUI-HARLEY-S19S1G2
3 Leden
2 handleidingen geschreven
Één opmerking
do you have the schematic of the board?
Jorge Herrera - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 1,663
