Ga door naar hoofdinhoud
IdeaPad Yoga 13 Battery Replacement
Wat je nodig hebt
  1. IdeaPad Yoga 13 Battery Replacement, Keyboard: stap 1, afbeelding 1 van 1
    • Power off your laptop before beginning disassembly.
    • Open the laptop to locate the keyboard.
  2. IdeaPad Yoga 13 Battery Replacement: stap 2, afbeelding 1 van 2 IdeaPad Yoga 13 Battery Replacement: stap 2, afbeelding 2 van 2
    • Insert a plastic opening tool in the seam between the keyboard and laptop body.
    • Carefully run the tool around the top and sides of the keyboard to pop out the 9 tabs holding in the keyboard.
  3. IdeaPad Yoga 13 Battery Replacement: stap 3, afbeelding 1 van 3 IdeaPad Yoga 13 Battery Replacement: stap 3, afbeelding 2 van 3 IdeaPad Yoga 13 Battery Replacement: stap 3, afbeelding 3 van 3
    • Lift the keyboard up, then pivot it towards you to lay it facedown on the trackpad and palm rests.
    • Be careful when lifting the keyboard up. The ribbon cable connecting it to the motherboard is very short, and the connector is fragile.
    • The top corners of the keyboard may be stuck to the laptop bezel with double sided tape. See rectangles in Image 3. Be careful as you lift the keyboard up and pivot it toward you.
  4. IdeaPad Yoga 13 Battery Replacement: stap 4, afbeelding 1 van 3 IdeaPad Yoga 13 Battery Replacement: stap 4, afbeelding 2 van 3 IdeaPad Yoga 13 Battery Replacement: stap 4, afbeelding 3 van 3
    • Locate the ribbon cable connecting the keyboard to the motherboard.
    • Use the tip of the opening tool to lift the black flap on the connector.
    • With the twezers, gently lift the ribbon cable out of the connector.
    • Be careful when reinserting the ribbon cable.
    • Ensure the cutouts on the end of the cable match the tabs on the connector.
  5. IdeaPad Yoga 13 Battery Replacement, Keyboard Bezel: stap 5, afbeelding 1 van 1
    • Locate and remove the screws holding the bezel to the laptop body:
    • Two 3 mm Phillips screws
    • Three 5.5 mm Phillips screws
  6. IdeaPad Yoga 13 Battery Replacement: stap 6, afbeelding 1 van 1
    • Flip the laptop over.
    • Locate and remove the screws holding the bezel to the bottom panel:
    • Ten 4.5 mm Phillips screws
  7. IdeaPad Yoga 13 Battery Replacement: stap 7, afbeelding 1 van 2 IdeaPad Yoga 13 Battery Replacement: stap 7, afbeelding 2 van 2
    • There is now nothing securing the bezel to the laptop body. However, there are still two cables connecting the bezel to the mainboard. Ensure the bezel remains in place until the cables are disconnected.
    • Flip the laptop back over.
    • Locate the small trackpad ribbon cable and use the opening tool to lift the black flap on the connector.
    • With tweezers, gently pull the ribbon cable out of the connector.
    • You can use the clear plastic tab on the top of the ribbon connector to help pull the cable out.
  8. IdeaPad Yoga 13 Battery Replacement: stap 8, afbeelding 1 van 1
    • Locate the power board cable and disconnect it by pulling the cable head towards the front of the laptop.
    • You can use a metal spudger to push the head out of the socket.
    • Be careful to not damage the socket.
  9. IdeaPad Yoga 13 Battery Replacement: stap 9, afbeelding 1 van 1
    • Lift the keyboard bezel off the laptop. The bezel is secured to the chassis by 10 plastic clips around the circumference that can be released with the plastic pry tool.
    • You may need to flip the screen around to get the necessary clearance at the hinges.
  10. IdeaPad Yoga 13 Battery Replacement, Battery: stap 10, afbeelding 1 van 1
    • Unplug the battery cable.
  11. IdeaPad Yoga 13 Battery Replacement: stap 11, afbeelding 1 van 1
    • Remove the screws holding the battery to the chassis:
    • Four 4 mm Philips screws
  12. IdeaPad Yoga 13 Battery Replacement: stap 12, afbeelding 1 van 1
    • Gently lift the battery out of the laptop.
    • Handle the battery carefully. Do not allow it to bend or be punctured.
Conclusie
12 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Does the battery sold by ifixit work with the Yoga IdeaPad 13 20175?
Jason Scott - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 59
Altijd: 15,303
