Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Loosen all of the strings completely by turning each tuning peg counter clockwise. Continue until there is no tension in the strings
Remove each string by pulling it out of the string tree at the top and through the bridge at the bottom.
Thread the largest new string through the bridge hole farthest from the knobs. Hold it firmly in place.
Pull the string up to the corresponding string tree.
Firmly grasp the middle of the string and pull it taut.
On a taut string, measure one inch past the nut before using a pair of wire cutters to cut the string.
Take the end of the string and insert it into the hole in the middle of the string tree.
Bend the string sideways into the channel of the string tree.
Use one hand to maintain tension in the string by grabbing the string and rotating the hand toward the fret board.
Rotate the tuning peg counterclockwise until the string is slightly taut, but not tight.
Check to ensure that the string is lined up with the proper notch in the nut.
Tighten the string until it is close to the proper tuning. Use an electronic tuner or an online tuner that uses your computer's microphone. (Google: Online Tuner)
Tune the thickest string to B, the second thickest string E, the next thickest to A, the next string to D, and the last string to G.
Because the strings will change pitch as the guitar body deforms due to increased tension, repeat step 12 after each string is tuned individually.
Één opmerking
Thanks for this, it's very helpful! However, I've always changed strings one at a time for two reasons - 1)keeping the tension on the neck is better than relieving it all at once, and 2) it's easier to tune the string. I usually start with the 1st string (lightest) and work my way up.
