Ga door naar hoofdinhoud
ICT Key Fob Battery Replacement
Wat je nodig hebt
  1. ICT Key Fob Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Place the key fob so that the back panel is facing up.
  2. ICT Key Fob Battery Replacement: stap 2, afbeelding 1 van 2 ICT Key Fob Battery Replacement: stap 2, afbeelding 2 van 2
    • Use the Phillips #00 screwdriver to remove three screws securing the battery compartment cover.
    • If there are no visible screws, the cover may be held in place by clips or a sliding mechanism.
    • Carefully open the compartment using a small tool if necessary.
  3. ICT Key Fob Battery Replacement: stap 3, afbeelding 1 van 1
    • Take note of the battery's orientation (positive terminal up) before removing it to ensure you insert the new battery correctly.
  4. ICT Key Fob Battery Replacement: stap 4, afbeelding 1 van 2 ICT Key Fob Battery Replacement: stap 4, afbeelding 2 van 2
    • Gently slide the battery out or lift it using an iFixit opening tool.
  5. ICT Key Fob Battery Replacement: stap 5, afbeelding 1 van 2 ICT Key Fob Battery Replacement: stap 5, afbeelding 2 van 2
    • Insert the new battery into the battery compartment, making sure to align it with the correct polarity (+ and -).
  6. ICT Key Fob Battery Replacement: stap 6, afbeelding 1 van 1
    • Press the new battery firmly into place to ensure a secure connection.
  7. ICT Key Fob Battery Replacement: stap 7, afbeelding 1 van 2 ICT Key Fob Battery Replacement: stap 7, afbeelding 2 van 2
    • Put the battery compartment cover back in place by tightening the three screws using a Phillips #00 screwdriver.
  8. ICT Key Fob Battery Replacement: stap 8, afbeelding 1 van 1
    • Press a button on the keyfob to ensure it's working properly with the new battery.
    • If the keyfob doesn't respond, double-check the battery orientation and try again.
Conclusie
If the correct battery type was used (and installed with the correct polarity in mind), the fob should now function. If the fob still does not function, the circuit board may be broken.
NOTE:
Remember to dispose of the old battery properly according to local regulations. If you encounter any difficulties or if the keyfob doesn't function correctly after replacing the battery, it's recommended to contact the manufacturer or seek professional assistance.
Één andere persoon heeft deze handleiding voltooid.
Nichita Bailuc
169 Reputatie
1 Handleiding geschreven
York University, Team M-1, Allen Summer 2023 Lid van York University, Team M-1, Allen Summer 2023
YORK-ALLEN-SU23SMG1
2 Leden
1 handleiding geschreven
3 opmerkingen
Thank you! You just made my day. I'm an 89 year old guy that needs some help sometimes. These fobs that they supply us for our underground parking garage in our retirement community don't seem to function very well. Thought I'd try changing batteries. Wish i could find a more powerful remote that would function with this system. We sometimes wonder if we are going to get in or out. They have had the overhead gate serviced a couple of times but it doesn't seem to help. thanks again, Arnie
Arnie Hansen - Antwoord
Hi Arnie, thank you for your comment really appreciate it. Glad we could help you.
Ibrahim Ahmed -
Well, I'm not 89 but I still found this helpful. Wasn't sure how to pull the battery out without damaging the little clamp that was holding it in place so the tip to pry it out, gently pushing from under it, was very helpful. Thank you!
Andrea - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 152
Altijd: 1,164
