Ga door naar hoofdinhoud
IBM Thinkpad T61 Trackpad Replacement
Wat je nodig hebt
  1. IBM Thinkpad T61 Trackpad Replacement, Trackpad: stap 1, afbeelding 1 van 1
    • Flip your computer over and remove the four indicated screws with the Phillips #1 screwdriver.
  2. IBM Thinkpad T61 Trackpad Replacement: stap 2, afbeelding 1 van 1
    • With the screws removed, the trackpad panel should lift as shown. Gently lift so the inside is visible.
  3. IBM Thinkpad T61 Trackpad Replacement: stap 3, afbeelding 1 van 2 IBM Thinkpad T61 Trackpad Replacement: stap 3, afbeelding 2 van 2
    • Gently remove the white plug to disconnect the trackpad panel from the bottom of the computer.
    • Use the screwdriver to remove the four screws from the trackpad. Two of the screws are located just under the plastic.
  4. IBM Thinkpad T61 Trackpad Replacement: stap 4, afbeelding 1 van 3 IBM Thinkpad T61 Trackpad Replacement: stap 4, afbeelding 2 van 3 IBM Thinkpad T61 Trackpad Replacement: stap 4, afbeelding 3 van 3
    • Separate the trackpad with the bottom mouse buttons from the trackpad panel.
  5. IBM Thinkpad T61 Trackpad Replacement: stap 5, afbeelding 1 van 1
    • Align the new trackpad so the screw holes line up with their insertion points. Replace the screws with the screwdriver.
  6. IBM Thinkpad T61 Trackpad Replacement: stap 6, afbeelding 1 van 1
    • Reinsert the white plug.
  7. IBM Thinkpad T61 Trackpad Replacement: stap 7, afbeelding 1 van 2 IBM Thinkpad T61 Trackpad Replacement: stap 7, afbeelding 2 van 2
    • Replace the trackpad panel.
    • Use the screwdriver to replace the screws, refastening the trackpad panel to the computer.
Conclusie
Replace the battery and plug in your computer. Test out your new trackpad!
6 andere personen hebben deze handleiding voltooid.
Raymond Lawton
245 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 6-6, Vijaybhaskar Spring 2014 Lid van UMass Dartmouth, Team 6-6, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G6
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 16
Altijd: 1,778
