Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the computer over so that the back is facing upwards.
Locate the screw in the bottom left-hand corner of the computer.
Using a #0 Phillips screwdriver, remove the 17 mm screw.
Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
Locate the folded black tab within the hard drive port.
With a screwdriver, pull the black tab out of the slot.
Pull gently on the black tab and the metal tray holding the hard drive will slide out.
Remove the plastic coverings on both sides of the hard drive.
7 andere personen hebben deze handleiding voltooid.
