Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Onderdelen
Geen onderdelen opgegeven.
  1. Turn the computer over so that the back is facing upwards.
    • Turn the computer over so that the back is facing upwards.
    • Locate the screw in the bottom left-hand corner of the computer.
  2. Using a #0 Phillips screwdriver, remove the 17 mm screw.
    • Using a #0 Phillips screwdriver, remove the 17 mm screw.
  3. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  4. Carefully remove the plastic piece covering the hard drive by first pulling up then away  from the computer.
    • Carefully remove the plastic piece covering the hard drive by first pulling up then away from the computer.
  5. Locate the folded black tab within the hard drive port. With a screwdriver, pull the black tab out of the slot.
    • Locate the folded black tab within the hard drive port.
    • With a screwdriver, pull the black tab out of the slot.
  6. Pull gently on the black tab and the metal tray holding the hard drive will slide out. Pull gently on the black tab and the metal tray holding the hard drive will slide out.
    • Pull gently on the black tab and the metal tray holding the hard drive will slide out.
  7. Remove the plastic coverings on both sides of the hard drive.
    • Remove the plastic coverings on both sides of the hard drive.
    • Note that there is no hard drive in this picture but the process will remain the same.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Kyle
377 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-58, Johann Spring 2013 Lid van Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Leden
10 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 45
Altijd: 4,434
