Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
If your computer has trouble reading discs and/or the disc drive is not working, it might need to be replaced. This guide will show you step by step how to replace the disc drive.
  1. Place the computer on its side so that the disc drive is facing up.
    • Place the computer on its side so that the disc drive is facing up.
    • Push in the release lever shown.
  2. Once the tab pops out, pull it away from the computer to release the disc drive.
    • Once the tab pops out, pull it away from the computer to release the disc drive.
  3. SLA DE UPGRADE OVER
    Bespaar door het te repareren met een alles-in-één kit.
    Koop iPhone-reparatiekits
    SLA DE UPGRADE OVER
  4. Pull the disc drive away from the laptop to fully remove it. Pull the disc drive away from the laptop to fully remove it.
    • Pull the disc drive away from the laptop to fully remove it.
  5. Insert new disk drive back into laptop
    • Insert new disk drive back into laptop
  6. Be sure to push the pull tab in as shown in the picture.
    • Be sure to push the pull tab in as shown in the picture.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Kyle
377 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-58, Johann Spring 2013 Lid van Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Leden
10 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 955
