Ga door naar hoofdinhoud
Inleiding
A laptop battery should last for about 2 to 4 years. Eventually your battery will need replacing. This process is very simple and can be achieved by following this guide.
  1. Ensure the laptop has been properly shut down and unplugged.
    • Ensure the laptop has been properly shut down and unplugged.
    • Turn the computer over so that you can see the battery release tab located near the top of the Thinkpad.
  2. Use your finger to slide the release tab to the unlocked symbol.
    • Use your finger to slide the release tab to the unlocked symbol.
  3. Hold the tab in the unlocked position and push the battery away from the computer to remove it. Hold the tab in the unlocked position and push the battery away from the computer to remove it. Hold the tab in the unlocked position and push the battery away from the computer to remove it.
    • Hold the tab in the unlocked position and push the battery away from the computer to remove it.
  4. Slide the new battery in until it clicks.
    • Slide the new battery in until it clicks.
    • Ensure that the release tab is in the locked position.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Kyle
377 Reputatie
4 handleidingen geschreven
Cal Poly, Team 8-58, Johann Spring 2013 Lid van Cal Poly, Team 8-58, Johann Spring 2013
CPSU-JOHANN-S13S8G58
4 Leden
10 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 2,512
