Ga door naar hoofdinhoud
IBM ThinkPad T43 CD Drive Replacement
Wat je nodig hebt
  1. IBM ThinkPad T43 CD Drive Replacement, CD Drive: stap 1, afbeelding 1 van 1
    • Start by having the right side of the laptop facing you.
    • The laptop can be open if you would like, but it can be done easier if it is closed.
  2. IBM ThinkPad T43 CD Drive Replacement: stap 2, afbeelding 1 van 1
    • Remove the screw to be able to use the CD drive unlock switch
  3. IBM ThinkPad T43 CD Drive Replacement: stap 3, afbeelding 1 van 1
    • Locate the switch on the right side of the CD Drive.
  4. IBM ThinkPad T43 CD Drive Replacement: stap 4, afbeelding 1 van 3 IBM ThinkPad T43 CD Drive Replacement: stap 4, afbeelding 2 van 3 IBM ThinkPad T43 CD Drive Replacement: stap 4, afbeelding 3 van 3
    • Place finger in between the switch and the bumper
    • Slide the switch to the right until the plastic tab ejects.
  5. IBM ThinkPad T43 CD Drive Replacement: stap 5, afbeelding 1 van 3 IBM ThinkPad T43 CD Drive Replacement: stap 5, afbeelding 2 van 3 IBM ThinkPad T43 CD Drive Replacement: stap 5, afbeelding 3 van 3
    • Place fingers on the plastic tab.
    • Pull on the tab until the CD Drive ejects.
    • The tab only comes out about an inch to inch and a half.
    • Do not try to pull the tab all the way out.
    • If after you have removed the CD Drive and the tab goes back in, it is alright. It does not affect the later process.
  6. IBM ThinkPad T43 CD Drive Replacement: stap 6, afbeelding 1 van 2 IBM ThinkPad T43 CD Drive Replacement: stap 6, afbeelding 2 van 2
    • Grab the end of the CD Drive and pulls straight out towards your body.
    • Be careful not to pull it out at an angle to not risk damage.
  7. IBM ThinkPad T43 CD Drive Replacement: stap 7, afbeelding 1 van 1
    • Now that you have successfully removed the CD Drive you can put in the new one.
    • Place the end of the new CD Drive in and slide in until it clicks.
    • If you are using slight force and it doesn't go in, it could be jammed. Just take it out and try again.
    • If you had not already, you can push back in the tab.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
aLiX pIeRRe
855 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team S6-G4, Bernier Spring 2018 Lid van UMass Dartmouth, Team S6-G4, Bernier Spring 2018
UMASSD-BERNIER-S18S6G4
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 15
Altijd: 889
