Ga door naar hoofdinhoud
IBM ThinkPad T42 Wi-Fi Card Replacement
Wat je nodig hebt
  1. IBM ThinkPad T42 Wi-Fi Card Replacement, Bottom cover: stap 1, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Wi-Fi Card Replacement, Rear screws: stap 2, afbeelding 1 van 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Wi-Fi Card Replacement, Keyboard and Trackpad: stap 3, afbeelding 1 van 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Wi-Fi Card Replacement: stap 4, afbeelding 1 van 2 IBM ThinkPad T42 Wi-Fi Card Replacement: stap 4, afbeelding 2 van 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Wi-Fi Card Replacement, Wi-Fi Card: stap 5, afbeelding 1 van 1
    • To remove Wi-Fi card, first disconnect both display wires on the top right.
  6. IBM ThinkPad T42 Wi-Fi Card Replacement: stap 6, afbeelding 1 van 1
    • Then slide both of the metal pieces holding it down outwards, and it will pop up.
  7. IBM ThinkPad T42 Wi-Fi Card Replacement: stap 7, afbeelding 1 van 1
    • Carefully pull it out.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kevin Rehm
472 Reputatie
4 handleidingen geschreven
Cal Poly, Team 29-76, Johann Spring 2010 Lid van Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Leden
35 handleidingen geschreven
Één opmerking
Get the HMM for the laptop! On a few of these, I have had to just pull out the internal wi-fi card, and use a USB wi-fi adapter.
Martin Campbell - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 17
Altijd: 13,728
