Ga door naar hoofdinhoud
Inleiding
Removing the optical drive is extremely easy and will only a take a minute.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the single screw holding the optical drive on the underside of the laptop
    • Remove the single screw holding the optical drive on the underside of the laptop
  2. iPhone Batterij Fix Kits
    Slechts $29.99
    Buy Now
    Slechts $29.99
    Buy Now
  3. Push the small slider to unlock position, a tab will automatically pop out.
    • Push the small slider to unlock position, a tab will automatically pop out.
  4. Pull the tab to dislodge the optical drive, then carefully pull the drive out.
    • Pull the tab to dislodge the optical drive, then carefully pull the drive out.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Gerald Watanabe
198 Reputatie
7 handleidingen geschreven
Cal Poly, Team 29-76, Johann Spring 2010 Lid van Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Leden
30 handleidingen geschreven
Één commentaar
What’s the interface for the optical drive? SATA? IDE?
Jonas Gamao - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 1
Afgelopen 30 Dagen: 4
Altijd: 4,981
