Ga door naar hoofdinhoud
IBM ThinkPad T42 Keyboard and Trackpad Replacement
Wat je nodig hebt
  1. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Bottom cover: stap 1, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Rear screws: stap 2, afbeelding 1 van 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
  3. IBM ThinkPad T42 Keyboard and Trackpad Replacement, Keyboard and Trackpad: stap 3, afbeelding 1 van 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Keyboard and Trackpad Replacement: stap 4, afbeelding 1 van 2 IBM ThinkPad T42 Keyboard and Trackpad Replacement: stap 4, afbeelding 2 van 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Austin Kidd
317 Reputatie
3 handleidingen geschreven
Cal Poly, Team 29-76, Johann Spring 2010 Lid van Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Leden
35 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 10,011
