Ga door naar hoofdinhoud
IBM ThinkPad T42 Fan Replacement
Wat je nodig hebt
  1. IBM ThinkPad T42 Fan Replacement, Bottom cover: stap 1, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, identify and unscrew the twenty screws located on the underside of the T42.
  2. IBM ThinkPad T42 Fan Replacement, Rear screws: stap 2, afbeelding 1 van 1
    • Unscrew the four Phillips screws located on either side of the rear of the T42 (there are two located on each end.)
    leave these four screws alone. No need to remove them.
    fredwb - Antwoord
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - Antwoord
  3. IBM ThinkPad T42 Fan Replacement, Keyboard and Trackpad: stap 3, afbeelding 1 van 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Fan Replacement: stap 4, afbeelding 1 van 2 IBM ThinkPad T42 Fan Replacement: stap 4, afbeelding 2 van 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: stap 5, afbeelding 1 van 2 IBM ThinkPad T42 Fan Replacement, Plastic Edge Cover: stap 5, afbeelding 2 van 2
    • Starting from the bottom right, carefully pry off the bezel. Use a spudger or flathead screwdriver if assistance is needed.
  6. IBM ThinkPad T42 Fan Replacement, Lower Bracket: stap 6, afbeelding 1 van 2 IBM ThinkPad T42 Fan Replacement, Lower Bracket: stap 6, afbeelding 2 van 2
    • Grasp the metal bracket to remove it from the device.
  7. IBM ThinkPad T42 Fan Replacement, Microphone cover: stap 7, afbeelding 1 van 1
    • Remove the rubber cover from the microphone.
  8. IBM ThinkPad T42 Fan Replacement, Fan Removal: stap 8, afbeelding 1 van 2 IBM ThinkPad T42 Fan Replacement, Fan Removal: stap 8, afbeelding 2 van 2
    • Using the Phillips #0 screwdriver, remove the three screws on the copper heatsink.
    • Separate the copper heatsink by pulling it upwards, in order to unplug the connector from the motherboard.
    • Due to the nature of old thermal paste, it might take some force to remove the heatsink.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Kevin Rehm
472 Reputatie
4 handleidingen geschreven
Cal Poly, Team 29-76, Johann Spring 2010 Lid van Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Leden
35 handleidingen geschreven
2 opmerkingen
How about you just down the freely available Hardware Maintenance Manual (HMM) for the laptop. They are downloadable in PDF format, and very well done.
Martin Campbell - Antwoord
It doesnt take this much, if you remove the palm rest and keyboard you can get it at an angle it slides straight out.
Tobyn Genn - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 29
Altijd: 26,252
