Ga door naar hoofdinhoud
Inleiding
Removal/repair of the display
Onderdelen
Geen onderdelen opgegeven.
  1. Unscrew the 20 Phillips screws on the underside of the T42.
    • Unscrew the 20 Phillips screws on the underside of the T42.
    • For ease of reassembly, keep your screws organized.
  2. Unscrew the 2 Phillips screws on both sides of the T42's rear.
    • Unscrew the 2 Phillips screws on both sides of the T42's rear.
    leave these four screws alone. No need to remove them.
    fredwb - Antwoord
    Of course you need to remove them you Dingbat! They are the main anchors of the screen hinges, Doh!
    wbcam -
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - Antwoord
  3. Flip the laptop over and open the screen.
    • Flip the laptop over and open the screen.
    • The bezel and keyboard will be loose, be careful.
  4. MacBook-reparatiesets voor batterijen
    Vanaf $69.99
    Buy Now
    Vanaf $69.99
    Buy Now
  5. Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together. Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  6. Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel. Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
    • Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
  7. Unscrew the screws holding down the display.
    • Unscrew the screws holding down the display.
    • Along with the one pictured in red, there is another one along the top right edge.
    could you post a pic of all the screws and where they go?
    Seth King - Antwoord
  8. Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
    • Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Austin Kidd
236 Reputatie
3 handleidingen geschreven
Cal Poly, Team 29-76, Johann Spring 2010 Lid van Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Leden
30 handleidingen geschreven
@Seth
Just use the pic numbering left to right each of the 4 rows.
Start at the top and remove in sequence, placing each on a strip of heavy tape to keep the screws in sequence.
Place a second strip on top when finished to secure the sequence until it's time to re-assemble.
Michael G - Antwoord
Very poor & sketchy guide! NO mention at all of how to handle the other wires involved in disconnecting the screen (lid) from the laptop base, eg: the wireless antenna connections and instructions like: "Unscrew the screws holding it down" are far too vague! holding WHAT down ffs!!!!
wbcam - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 3
Afgelopen 30 Dagen: 16
Altijd: 11,992
